Sep 17th, 2026, 9:19pm
how to create macromodel in spectre (Read 4833 times)
avlsi
singapore
Nov 09th, 2006, 11:09pm
I want to design to a macromodel with components like capacitors ,resistors to emulate a device. So that i can use it like the VCVS as used for running opamp based simulations.
I would like to know the way to create the macromodel and then use it.
Thanks in advance.
Winners never Quit,Quitters never Win
Re: how to create macromodel in spectre
Reply #1 - Nov 10th, 2006, 7:19am
Use Verilog-A. It is available in every copy of Spectre.
avlsi
singapore
Reply #2 - Nov 25th, 2006, 11:30pm
hi,
I actually want to calculate a capacitance value based on the voltages given to its terminals. I have done this in SPICE.
I was using V(node1, node2) to get the voltage and calculate the capacitance values using an expression.
In spectre, I am unable to do the same thing. I am getting an error.
Is there a better way to use voltages in expressions.
Thanks in advance.
RE
Reply #3 - Nov 26th, 2006, 4:19pm
The approach you are trying to take is very common, but is not correct. Doing it that way leads to a variety of problems. See http://www.designers-guide.org/Modeling/varactors.pdf for a description of what can go wrong it you use that approach and how to model a capacitor correctly.
Reply #4 - Dec 12th, 2006, 2:17pm
I agree entirely with Ken in this specific case, but it is possible to formulate voltage dependent capacitors (preferrably using a charge-based approach) using the "bsource" component in spectre. This is internally implemented in Verilog-A, and allows voltage or current dependencies to be expressed using spectre syntax.
See spectre -h bsource for more details, or look in the documentation.
However, Verilog-A is a good thing to learn and have under your belt - it gives you far more flexibility than bsource does. Ken and Olaf's book The Designer's Guide to Verilog-AMS is a good place to start on this.
