Jul 20th, 2024, 6:20pm
How to probe vth during DC sweep? (Read 3163 times)
Daniel_Platte
Munich/Germany
Nov 21st, 2006, 8:29am
Hi NG,
Is there a way to probe device model internal values (e.g. vth of a BSIM3v3 model instance) during Spectre's DC sweep?
Cheers,
Daniel
ACWWong
Oxford, UK
Re: How to probe vth during DC sweep?
Reply #1 - Nov 21st, 2006, 9:18am
you use the save statement and then get the data from the results directory
save I0:vth
then get the data with:
getData( "bob:vth" ?result "dc-dc")
see the post for details
http://www.designers-guide.org/Forum/YaBB.pl?num=1159012341/2#2
ACWWong
Oxford, UK
Reply #2 - Nov 21st, 2006, 9:19am
oops... i meant
getData( "I0:vth" ?result "dc-dc")
Reply #3 - Dec 12th, 2006, 2:26pm
BTW, it's usually a good idea to use the aliased name for the analysis in OCEAN expresisons - because this then means you can use the expression in (say) monte-carlo.
So that would be
getData("I0:vth" ?result "dc")
