Jul 20th, 2024, 6:24pm
Using a SKILL function in a MonteExpr in OCEAN? (Read 84 times)
JosephRyan
Nov 11th, 2006, 1:48am
Is it possible to use a SKILL function as the scalar expression of monteExpr() instead of a calculator function?  I'd like to use a custom function to will implement a binary search (to calculate the body-offset voltage of a Sense Amp), but using anything except a calculator function gives me errors!  I need to use a custom function since I'll need to run several simulations per monte-carlo change (that is, for every time the monte-carlo simulation changes the Vts of the transistors, it will need to run about 6-8 transient simulations).    As an example, take the following simplified code:
procedure( cboffset()
    i = 2
    i
monteCarlo( ?numIters 2 ?analysisVariation 'mismatch ?sweptParam "None" ?sweptParamVals "25" ?saveData t )
monteExpr( "boffset" "cboffset()")
monteRun()
monteResults()
The cboffset function just returns 2 every time in this example, but would eventually implement a binary search.  However, this example will cause errors since the monteExpr will not evaluate.  Can anyone help?
Re: Using a SKILL function in a MonteExpr in OCEAN
Reply #1 - Dec 12th, 2006, 2:55pm
Do you have sourcelink access? I wrote a solution on this - solution number 11007118 covers using custom SKILL functions in monteExpr and gives two different ways of solving this.
