Is it possible to use a SKILL function as the scalar expression of monteExpr() instead of a calculator function? I'd like to use a custom function to will implement a binary search (to calculate the body-offset voltage of a Sense Amp), but using anything except a calculator function gives me errors! I need to use a custom function since I'll need to run several simulations per monte-carlo change (that is, for every time the monte-carlo simulation changes the Vts of the transistors, it will need to run about 6-8 transient simulations). As an example, take the following simplified code:
Code:procedure( cboffset()
i = 2
i
monteCarlo( ?numIters 2 ?analysisVariation 'mismatch ?sweptParam "None" ?sweptParamVals "25" ?saveData t )
monteExpr( "boffset" "cboffset()")
monteRun()
monteResults()
The cboffset function just returns 2 every time in this example, but would eventually implement a binary search. However, this example will cause errors since the monteExpr will not evaluate. Can anyone help?
