Sep 27th, 2026, 12:03am
how we probe local variables in verilog-A sim (Read 3945 times)
neoflash
Mixed-Signal
Designer
Nov 15th, 2006, 9:35pm
I am using hspice simulator. How to observe those internal non-electrical signals?
Re: how we probe local variables in verilog-A sim
Reply #1 - Nov 16th, 2006, 11:27am
Per the new Verilog-AMS LRM, you can define output variables with attributes,
If you have a variable called "iavl" that is used to store the avalanche current, declare it at top level (module scope, not in a named block) with
(* desc="avalanche current" *) real iavl;
(and, obviously, remove the declaration you had before).  I believe HSpice supports this new feature.  I forget the exact syntax, though, for requesting that HSpice save it to the .tr0 file; I think it's similar to what you do for saving "gm" from a transistor.
neoflash
Mixed-Signal
Designer
Reply #2 - Nov 18th, 2006, 6:15am
oh.
Maybe I will check with hspice manual. It is quite ridiculous that my CAD engineer does not install the manual with new version simulator, thus I have to live without that for quite long time, until that guy have time to handle my request...
