Sep 27th, 2026, 7:29pm
Synthesis Problem With Capture Program (Read 2418 times)
EEStyx
Nov 23rd, 2006, 5:55pm
I am trying to make a program that captures the codes from an infrared decoder. I designed this program to measure the time between the bits (unipolar, return to zero) and determine what the last bit was.
The problem is that every time I compile the program using Quartus II (version 5) the compiler sythesizes away all of the registers to GND. I think it might have something to do with the time required for the logic to do anything, but I'm not sure. Does anyone have any ideas? Any help on the issue would be GREATLY appreciated.
Thanks in advance.
The Code:
(Note: There is an additional always block after this, but its only used to display the stored codes to a 7-seg display)
(Note: There have been comments added, so pay attention to the comment lines)
module NewCapture (Clk100khz, irIn, WordOut, Cycle, DipIn, CaptureEn, Reset);
     input Clk100khz, irIn, Cycle, Reset;
     input [3:0] DipIn;
     output [7:0] WordOut;
     output CaptureEn;
     reg [7:0] WordOut;
     reg [11:0] OffTime; // Used to count the space between logic one's
     reg [11:0] OnTime; // Used to count the on-time: used for verification of the 'start' code
     reg [55:0] CurrentWord; // Used to store the incomming instruction set
     // Each intsruction set will be stored to a different register for evaluation
     // A total of 10 instructions may be stored
     reg [55:0] Instrctn1, Instrctn2, Instrctn3, Instrctn4, Instrctn5;
     reg [55:0] Instrctn6, Instrctn7, Instrctn8, Instrctn9, Instrctn10;
     // Used to evaluate the previous status of ir compared to the current value
     // Will be used to find the rising edge of irIn.
     reg PrevIrVal;
     reg CaptureEn; // If it is ok to enable code-storing
     reg [1:0] PrevBit;
     reg [3:0] CodeNum; // Used to determine which instruction set is being stored
     reg StartCode; // If the start code FF has been seen, set StartCode
     // For displaying the code to the 7-seg displays
     reg [55:0] DispTemp;
     integer n;
always @ (posedge Clk100khz)
begin
if (!CaptureEn)
     begin
     if (irIn)
           begin
           OnTime = OnTime + 1;
           // if the irIn is on for more than 8-bits, non-return to zero
           // then the start code has been recieved
           if (OnTime >> 12'h320) // Time value for start code of '11111111' of '111111110000'
                 begin
                 OnTime = 0;
                 StartCode = 1;
                 end // end if (OnTime >> value)
           end // end if (irIn)
     else // else, then irIn is false
           begin
           OnTime = 0;
           if (StartCode) CaptureEn = 1;
           else;
     end // end if (!CaptureEn)
else if (CaptureEn)
     begin
     StartCode = 0;
     // find the rising edge of irIn to compute and store ir-code
     if (irIn && !PrevIrVal)
           begin
           OffTime = 0;
           PrevIrVal = 1;
           CurrentWord = CurrentWord << 1;
           // if a '11x' was recieved
           // Tmin = 40 < time < Tmax = 80
           if ((OffTime >> 12'h028) && (OffTime << 12'h050))
                 begin
                 CurrentWord[0] = 1;
                 PrevBit = 2'b11; // bit was 1
           // if a '10x' was recieved
           // Tmin = 50h, Tmax = BAh
           else if ((OffTime >> 12'h050) && (OffTime << 12'h0BA))
                 begin
                 CurrentWord[1:0] = 2'b01;
                 PrevBit = 2'b10; // bit was 0
           // if a '100x' was recieved
           // Tmin = EFh Tmax = 2B3
           else if ((OffTime >> 12'h0EF) && (OffTime << 12'h10A))
                 begin
                 CurrentWord = CurrentWord >> 1;
                 //CurrentWord[0] = 1;
                 PrevBit = 2'b01; // error or end of instruction
           // of a '1000x' was recieved
           else if ((OffTime >> 12'h10A) && (OffTime << 12'h175))
                 begin
                 PrevBit = 2'b01;
           // if a 'x00001' was recived
           else if (OffTime >> 12'h175)
                 begin
                 CurrentWord[0] = 1;
                 PrevBit = 2'b11;
           else;
           end // end if (irIn && !PrevValue)
     else if (!irIn)
           begin
           PrevIrVal = 0;
           OffTime = OffTime + 1;
           // if between instruction bits:
           // if 8 zeros in a row:
           if (OffTime == 12'h2C4)
                 begin
                 if (CodeNum == 4'b0000)
                       begin
                       Instrctn1 = 0;
                       Instrctn1 = CurrentWord;
                 else if (CodeNum == 4'b0001)
                       begin
                       Instrctn2 = 0;
                       Instrctn2 = CurrentWord;
                 else if (CodeNum == 4'b0010)
                       begin
                       Instrctn3 = 0;
                       Instrctn3 = CurrentWord;
                 else if (CodeNum == 4'b0011)
                       begin
                       Instrctn4 = 0;
                       Instrctn4 = CurrentWord;
                 else if (CodeNum == 4'b0100)
                       begin
                       Instrctn5 = 0;
                       Instrctn5 = CurrentWord;
                 else if (CodeNum == 4'b0101)
                       begin
                       Instrctn6 = 0;
                       Instrctn6 = CurrentWord;
                 else if (CodeNum == 4'b0110)
                       begin
                       Instrctn7 = 0;
                       Instrctn7 = CurrentWord;
                 else if (CodeNum == 4'b0111)
                       begin
                       Instrctn8 = 0;
                       Instrctn8 = CurrentWord;
                 else if (CodeNum == 4'b1000)
                       begin
                       Instrctn9 = 0;
                       Instrctn9 = CurrentWord;
                 else if (CodeNum == 4'b1001)
                       begin
                       Instrctn10 = 0;
                       Instrctn10 = CurrentWord;
                 else;
                 CodeNum = CodeNum + 1;
                 CurrentWord = 0;
                 end // end if ((OffTime >> 12'h2C4) && (OffTime << 12'h881))
           // if more than 20 bits have passed, the button is done
           else if (OffTime >> 12'h881)
                 begin
                 CodeNum = 4'b0000;
                 CaptureEn = 0;
                 OffTime = 0;
           else;
           end // end else if (!irIn)
     end // end else if (CaptureEn)
else;
end // end always
jbdavid
Re: Synthesis Problem With Capture Program
Reply #1 - Dec 8th, 2006, 11:22pm
Many have read this, but few reply.. mainly because most of the eyeballs watching this forum are driven by analog guys...
jbdavid
EEStyx
Reply #2 - Dec 11th, 2006, 9:54am
To anyone who was interested in the solution, I was finally able to determine why it wasn't working correctly.
The program that was posted uses all blocking statements ( = ). For some reason, unknown to me, the synthesis program interrpreted these incorrectly and compiled all storage registers to grounds. When all the statements are changed to non-blocking ( <= ) everything works perfectly.
Like I say, Im not sure why it works like that, but it does.
