Jul 16th, 2024, 12:34pm
array initialization in Verilog (Read 3549 times)
Pavel
Lausanne/Switzerland
Nov 29th, 2006, 7:45am
Hello
For my test bench I need in 8-member array of 11-bit constants.
Only approach I found working is:
	reg  [10:0]  local_PWDN_etalon [0:7];
	initial begin
		local_PWDN_etalon [0] =  11'b00000011100;
		local_PWDN_etalon [1] =  11'b00000011000;
		local_PWDN_etalon [2] =  11'b00000011100;
		local_PWDN_etalon [3] =  11'b00000011100;
		local_PWDN_etalon [4] =  11'b11111111111;
		local_PWDN_etalon [5] =  11'b01111111011;
		local_PWDN_etalon [6] =  11'bx;
		local_PWDN_etalon [7] =  11'b00000011101;
Is there a possibility to avoid using construction initial?
Regards.
Pavel.
jbdavid
Re: array initialization in Verilog
Reply #1 - Dec 8th, 2006, 11:20pm
of course,
you can define the values in a text file and do readmemh
but its still probably in the inital block..
any verilog text book will have other ways of doing this..
Jonathan
jbdavid
Reply #2 - Dec 9th, 2006, 10:03am
Why do you want to avoid using initial?
