EEStyx
I am trying to make a program that captures the codes from an infrared decoder. I designed this program to measure the time between the bits (unipolar, return to zero) and determine what the last bit was.
The problem is that every time I compile the program using Quartus II (version 5) the compiler sythesizes away all of the registers to GND. I think it might have something to do with the time required for the logic to do anything, but I'm not sure. Does anyone have any ideas? Any help on the issue would be GREATLY appreciated.
Thanks in advance.
The Code: (Note: There is an additional always block after this, but its only used to display the stored codes to a 7-seg display) (Note: There have been comments added, so pay attention to the comment lines)
module NewCapture (Clk100khz, irIn, WordOut, Cycle, DipIn, CaptureEn, Reset); input Clk100khz, irIn, Cycle, Reset; input [3:0] DipIn; output [7:0] WordOut; output CaptureEn; reg [7:0] WordOut; reg [11:0] OffTime; // Used to count the space between logic one's reg [11:0] OnTime; // Used to count the on-time: used for verification of the 'start' code reg [55:0] CurrentWord; // Used to store the incomming instruction set // Each intsruction set will be stored to a different register for evaluation // A total of 10 instructions may be stored reg [55:0] Instrctn1, Instrctn2, Instrctn3, Instrctn4, Instrctn5; reg [55:0] Instrctn6, Instrctn7, Instrctn8, Instrctn9, Instrctn10; // Used to evaluate the previous status of ir compared to the current value // Will be used to find the rising edge of irIn. reg PrevIrVal; reg CaptureEn; // If it is ok to enable code-storing reg [1:0] PrevBit; reg [3:0] CodeNum; // Used to determine which instruction set is being stored reg StartCode; // If the start code FF has been seen, set StartCode // For displaying the code to the 7-seg displays reg [55:0] DispTemp; integer n; always @ (posedge Clk100khz) begin
if (!CaptureEn) begin if (irIn) begin OnTime = OnTime + 1; // if the irIn is on for more than 8-bits, non-return to zero // then the start code has been recieved if (OnTime >> 12'h320) // Time value for start code of '11111111' of '111111110000' begin OnTime = 0; StartCode = 1; end // end if (OnTime >> value) end // end if (irIn) else // else, then irIn is false begin OnTime = 0; if (StartCode) CaptureEn = 1; else; end end // end if (!CaptureEn)
else if (CaptureEn) begin StartCode = 0; // find the rising edge of irIn to compute and store ir-code if (irIn && !PrevIrVal) begin OffTime = 0; PrevIrVal = 1; CurrentWord = CurrentWord << 1; // if a '11x' was recieved // Tmin = 40 < time < Tmax = 80 if ((OffTime >> 12'h028) && (OffTime << 12'h050)) begin CurrentWord[0] = 1; PrevBit = 2'b11; // bit was 1 end // if a '10x' was recieved // Tmin = 50h, Tmax = BAh else if ((OffTime >> 12'h050) && (OffTime << 12'h0BA)) begin CurrentWord = CurrentWord << 1; CurrentWord[1:0] = 2'b01; PrevBit = 2'b10; // bit was 0 end // if a '100x' was recieved // Tmin = EFh Tmax = 2B3 else if ((OffTime >> 12'h0EF) && (OffTime << 12'h10A)) begin CurrentWord = CurrentWord >> 1; //CurrentWord[0] = 1; PrevBit = 2'b01; // error or end of instruction end // of a '1000x' was recieved else if ((OffTime >> 12'h10A) && (OffTime << 12'h175)) begin CurrentWord = CurrentWord >> 1; PrevBit = 2'b01; end // if a 'x00001' was recived else if (OffTime >> 12'h175) begin CurrentWord[0] = 1; PrevBit = 2'b11; end else; end // end if (irIn && !PrevValue) else if (!irIn) begin PrevIrVal = 0; OffTime = OffTime + 1; // if between instruction bits: // if 8 zeros in a row: if (OffTime == 12'h2C4) begin if (CodeNum == 4'b0000) begin Instrctn1 = 0; Instrctn1 = CurrentWord; end else if (CodeNum == 4'b0001) begin Instrctn2 = 0; Instrctn2 = CurrentWord; end else if (CodeNum == 4'b0010) begin Instrctn3 = 0; Instrctn3 = CurrentWord; end else if (CodeNum == 4'b0011) begin Instrctn4 = 0; Instrctn4 = CurrentWord; end else if (CodeNum == 4'b0100) begin Instrctn5 = 0; Instrctn5 = CurrentWord; end else if (CodeNum == 4'b0101) begin Instrctn6 = 0; Instrctn6 = CurrentWord; end else if (CodeNum == 4'b0110) begin Instrctn7 = 0; Instrctn7 = CurrentWord; end else if (CodeNum == 4'b0111) begin Instrctn8 = 0; Instrctn8 = CurrentWord; end else if (CodeNum == 4'b1000) begin Instrctn9 = 0; Instrctn9 = CurrentWord; end else if (CodeNum == 4'b1001) begin Instrctn10 = 0; Instrctn10 = CurrentWord; end else; CodeNum = CodeNum + 1; CurrentWord = 0; end // end if ((OffTime >> 12'h2C4) && (OffTime << 12'h881)) // if more than 20 bits have passed, the button is done else if (OffTime >> 12'h881) begin CodeNum = 4'b0000; CaptureEn = 0; OffTime = 0; end else; end // end else if (!irIn) end // end else if (CaptureEn) else; end // end always endmodule
