Aug 26th, 2024, 3:15am
Zero Diagonal Found in Jacobian! (Read 5224 times)
schehrazi
University of CA, LA
Nov 26th, 2006, 10:06am
When does Spectre prompt the following convergence issue?
Zero diagonal found in Jacobian at 'nodeX' and 'nodeX'
Does a certain circuit condition lead to this error? I should say that I am trying to simulate a mixer with VerilogA square law transistors using PSS. I am My VerilogA model covers both saturation and triode operation regions.
Thank you so much.
Re: Zero Diagonal Found in Jacobian!
Reply #1 - Nov 27th, 2006, 5:16am
You've probably got a poorly-defined model.  What happens in subthreshold?  If you don't have a GMIN or subthreshold current equation, then you'd likely get a zero diagonal message.  The Jacobian (matrix) is loaded with partial derivatives of all the currents with respect to the node voltages.  If there's a zero diagonal at nodeX, then it means that, when linearized about the operating point, changing the voltage on nodeX will not affect the current into nodeX.
schehrazi
Reply #2 - Dec 12th, 2006, 11:12am
Thanks, I fixed it by changing the initial condition parameters of PSS.
