Jul 17th, 2024, 10:35am
Differential OTA stability... (Read 6289 times)
redentore
Nov 27th, 2006, 8:59am
Hi! I need to plot gain loop of a OTA with capacity feedback.
I tried to use spectre's STB analysis,, but the results doesn't look good.
How do I select the probe for the analysis in a differential circuit (I tried to select one transistor of the differential pair and tried to break the one feedback with a probe, but doesn't seem to work)?
Can someone write me a step by step tutorial?
Thank you very much!
Re: Differential OTA stability...
Reply #1 - Nov 27th, 2006, 6:38pm
Try "spectre -h stb". There are instructions on how to apply stb to differential circuits there.
redentore
Reply #2 - Nov 28th, 2006, 2:20am
One last question: how do I converti this netlist into a circuit?
   subckt diffprobe x1in x2in x1out x2out
       ibranch inout x1out iprobe
       vinj inout x1in iprobe
       evinj x2in x2out x1in x1out vcvs gain=0
       fiinj 0 x2out pcccs probes=[ibranch vinj] coeffs=[0 1 1] gain=0
   ends diffprobe
ACWWong
Oxford, UK
Reply #3 - Nov 28th, 2006, 3:19am
you can draw it based on the netlist using analoglib iprobe, vcvs and pcccs....
Or if you have access to it you can use the drawn for you component: analoglib.cmdmprobe
redentore
Reply #4 - Nov 28th, 2006, 7:22am
Ok, I found the component.
I plotted the loop gain but there is a little problem: the zero crossing frequency from the loop gain is different from the frequency of the domint pole. Can this be possible? In theory the domint pole frequency and the zero crossing of the loop gain should be the same.
ACWWong
Oxford, UK
Reply #5 - Nov 28th, 2006, 8:44am
The dominant pole freq is when the loop gain is reduced by 3dB.
It is NOT the frequency at which loop gain is 1 (0dB). When the loop gain does cross 0dB you need to ensure good phase margin.
redentore
Reply #6 - Nov 28th, 2006, 9:06am
Sorry, I think I haven't made myself clear.
Since H=A/(1+T) =~A/T -> T=a/H -> (T)dB = (a)dB - (H)dB, being a the open loop gain, H the closed loop gain and T the loop gain.
In this approximation the closed loop -3dB frequency should be the zero crossing frequency on the loop gain.
Croaker
Reply #7 - Nov 29th, 2006, 4:24pm
Yes, sounds like you are plotting H=1/B (closed-loop gain) and A (open-loop gain) on the same graph, and the difference is the loop-gain.  OK.
Your assumption is correct assuming the A*B >> 1 and 1/B intersects at a -20 dB point.  Maybe you have a second pole in your open-loop response.  If so, there will be an increase in downward slope, though sometimes it's a little tricky to see.
