Oct 19th, 2024, 3:04pm
how to make a noise source? (Read 5161 times)
Aigneryu
Nov 28th, 2006, 1:55pm
 I tried to make an ideal noise source with a predefined noise spectrum in order to find out how
different injecting nodes give different transfer properties.
Is it possible to make a noise source, say, current source with zero DC current and open impedence?
Re: how to make a noise source?
Reply #1 - Nov 28th, 2006, 3:01pm
If you are using Spectre none of this is necessary. Just use xf analysis with 'stimuli' set to nodes_and_terminals.
Yutao Liu
Guangzhou, China
Reply #2 - Nov 17th, 2012, 10:45pm
Ken Kundert wrote on Nov 28th, 2006, 3:01pm:
Hello Ken,
For XF simulation in ADE, only the output terminal can be set. And after the simulation, only the "port" and "vdc" can be available to plot the transfer function. What if the voltage-controlled voltage source. Can I use the method you mentioned above?
And where I can find information about 'stimuli' setting?
Yutao Liu
rfidea
Europe
Reply #3 - Nov 18th, 2012, 6:07am
You can set noise/frequency points in the idc source from analogLib.
Yutao Liu
Guangzhou, China
Reply #4 - Nov 19th, 2012, 4:59am
rfidea wrote on Nov 18th, 2012, 6:07am:
Thanks for your reply.
Could you tell me some detail?
Actually, I made a phase domain behavioral model of pll with component in analogLib. I used vccs to model the charge pump, vcvs to model an amplifier. I want to simulate the noise shaping effect for a given noise source, like resistor in the loop filter or charge pump.
Is XF simulation able to get what I want? How to do that?
Yutao Liu
Reply #5 - Nov 19th, 2012, 12:16pm
It is in the XF options form.
rfidea
Europe
Reply #6 - Nov 19th, 2012, 12:25pm
I do not have the Virtuoso environment in front of me but there is parameters in the components options list called noise/frequency pairs. Just fill in what you want.
About resistors, yes, spectre will calculate thermal noise from them. That is the idea with a simulator.
