Hello
For my test bench I need in 8-member array of 11-bit constants.
Only approach I found working is:
Code: reg [10:0] local_PWDN_etalon [0:7];
initial begin
local_PWDN_etalon [0] = 11'b00000011100;
local_PWDN_etalon [1] = 11'b00000011000;
local_PWDN_etalon [2] = 11'b00000011100;
local_PWDN_etalon [3] = 11'b00000011100;
local_PWDN_etalon [4] = 11'b11111111111;
local_PWDN_etalon [5] = 11'b01111111011;
local_PWDN_etalon [6] = 11'bx;
local_PWDN_etalon [7] = 11'b00000011101;
Is there a possibility to avoid using construction
initial?
Regards.
Pavel.
