Aug 18th, 2024, 1:11am
inductance of the exposed pad bondwire (Read 4936 times)
michael_li
Dec 04th, 2006, 6:20am
In my 2000MHz PA Driver circuit design,I use bondwire inductor emitter negative feedback.
To get higher gain,I bond the emitter to the Exposed Pad of the QFN48 package,so the bondwire inductance is estimated 1nH.Is that right,or it should be 500pH?
Undecided
ACWWong
Oxford, UK
Re: inductance of the exposed pad bondwire
Reply #1 - Dec 4th, 2006, 6:50am
It depends on how long it is (and other dimensions) and what the adjacent bondwires are etc. etc.
So 1nH is ok as an approximation for the self inductance of a 1mm length of bondwire. 0.5nH is ok for something like 0.6mm. Depending on adjacent bondwires, mutal inductance can act to change the effective value you use.
You can find references to bondwire inductance formulae in something like Tom Lee's "Design of CMOS Radio Frequency Integrated Circuits"
Reply #2 - Dec 4th, 2006, 9:21am
In addition to the textbook references, electromagnetic model tools (Sonnett, ASITIC, and others) will allow development of an inductance and magentic coupling model.
Manufacturers of the QFN package (popular in RF circles due to low L) also develop more complete package models for their customers.
Jerry
ACWWong
Oxford, UK
Reply #3 - Dec 4th, 2006, 9:33am
yes best port of call is are your packaging people... as loose says, they normally can give you some model data:
I just googled and found this:
http://www.ose.com.tw/ic/en/packaging_service.asp
but you could also try amkor or unisem...
Reply #4 - Dec 4th, 2006, 1:26pm
Amkor is pretty good at developing package models for their products. Good results seen from them!  :)
michael_li
Reply #5 - Dec 5th, 2006, 1:59am
You are so kind.
Thanks all of you.
So I will check it with the package factory.
