Aug 18th, 2024, 3:14am
Beat Freuqnency in SpectreRF PSS simulation (Read 2759 times)
adesign
Dec 07th, 2006, 9:28pm
While doing pss setup, the simulator asks for "beat frequency". Please explain what is "Beat frequency in SpectreRF PSS simulation".
I'm doing a ring-oscillator simulation and the expected output frequency is 384MHz. In this case, what value of beat frequency should I feed and why?
Re: Beat Freuqnency in SpectreRF PSS simulation
Reply #1 - Dec 8th, 2006, 12:27am
The term "beat frequency" is a very poor choice because it does not apply in the most common case, which is when there is only one fundamental frequency present. In that situation you need to put the fundamental frequency (or in with oscillators, you give an estimate of the fundamental frequency) in that field. In your case, 384MHz.
adesign
Reply #2 - Dec 8th, 2006, 12:43am
Thank you Ken!
