Aigneryu
Thanks Geoffrey,
So does that mean, there is no problem with that code itself but on spectre? because I can never get it correctly compiled. I have to remark the conditional def in order to get it work. Is that true? Since you said that it should be correct to use ddx in a conditional, what should I do with it?
The error message said " The first argument specified for ddx operator contains an expression that cannot be symbollically calculated", but after I back trace the equations for Ids, I think it should be symbolically solvable.
It there any way I can do for this?
