Jul 16th, 2024, 12:30pm
How to parameterize a string variable (Read 4707 times)
naone
San Diego
Dec 15th, 2006, 11:41am
I am trying to pass a string parameter into a verilogA file to use as the filename for an include file:
This is what I am trying but have syntax errors:
parameter filename = "incfile.txt"
`include filename
This does not work.  I also tried `include(filename) and this did not work either.
Any help is greatly appreciated.
Naone
Re: How to parameterize a string variable
Reply #1 - Dec 18th, 2006, 6:31am
I'm almost sure you can't do this at all; the problem is that `include is a preprocessor directive, handled by the compiler, well before anything else happens.
What are you trying to bring in in that include file, though?  Usually, include files tell the compiler something about how to compile; I guess you're trying to bring in some information for simulation, so you may be able to bring in the data another way (eg, $table_model).
-Geoffrey
jbdavid
Reply #2 - Feb 9th, 2007, 3:13am
If you want to set some variables from the file, you can use
parameter string myFile = "default file name"
then
FH = $fopen( myFile, r): <- I don't remember how this works
var1 = $fscanf(FH);
jbdavid
Reply #3 - Feb 9th, 2007, 6:19am
jbdavid wrote on Feb 9th, 2007, 3:13am:
In what simulator?  I know it's in the LRM; I'm not aware of any simulators that support it yet ...
Reply #4 - Feb 22nd, 2007, 11:09am
Spectre does. I filed a PCR a while ago because string parameters weren't working in case statements, but that works now (in MMSIM60 and MMSIM61 versions for about a year). I just took the example I had with a case statement, and tried it out with fopen too - and that worked:
`include "discipline.h"
`include "constants.h"
module resexample (a,b);
inout  a,b;
electrical  a,b;
branch (a,b) resbr;
parameter real w=1u,l=1u,rsh1=1000.0,rsh2=400.0,rsh3=200.0;
parameter string rtype="M1";
real rval;
integer FH;
analog begin
    case (rtype)
    "M1": rval=rsh1*w/l;
    "M2": rval=rsh2*w/l;
    default: rval=rsh3*w/l;
    endcase
    $strobe("rtype is %s, rval is %g",rtype,rval);
    FH=$fopen(rtype,"w");
    $fstrobe(FH,"rtype is %s, rval is %g",rtype,rval);
    $fclose(FH);
    V(resbr) <+ rval*I(resbr);
with this netlist:
r1 (1 0) resexample w=2u l=0.5u rtype="M2"
v1 (1 0) vsource type=dc dc=1
ahdl_include "resexample.va"
dc dc write=stuff.dc
It wrote out:
 rtype is M2, rval is 1600
both to the screen, and into a file called "M2".
