Jul 16th, 2024, 1:29am
The speaker spice model in the class d amp design (Read 6474 times)
dandelion
Dec 18th, 2006, 2:18am
We are developing a class d audio amplifier whivh is used in the PDA or GSM mobile phones. The amplifier is filterless, i.e. the amplifier is driving the speaker load directly. I wonder, in the designing phase, how should i model the speaker load? A simple inductor seried with parallel connected Cap and Rload is enough for the design? If so, what is the value of the inductor and cap?
johnharris
Re: The speaker spice model in the class d amp des
Reply #1 - Feb 15th, 2007, 3:29pm
Hey,
Check out http://www.triplexfx.iceamplifiers.co.uk/ssmg.php.
Its got a Spice model generator that will produce a model of a speaker from parameters that you enter. You should be able to get hold of these from any manufacturer.
Wink
John
