In fact I'd recommend a newer spectre version (MMSIM60 or MMSIM61) which can natively read SPICE syntax without needing to go through the spp preprocessor. This is both quicker, has better error reporting, and more thorough.
In IC5141, you can add the +csfe command line switch, and it will invoke the new front-end parser (it was introduced in IC5141, but not made the default).
