Alm
Is there a way for getting HSPICE to write the .print results to a file instead of on the screen?
If I simply write hspice file1.spice > out1.spice the entire output including spice netlist, model files get written. I want to avoid that and only write the results obtained using .PRINT statement. ie .print V(I2)
If the above is not possible, is the only possible option to get the entire out file and write some scripts to pick up the relevant information?
Thanks, Alm
