Oct 18th, 2025, 11:23am
spectre simulation error (Read 3950 times)
xwcwc1234
TAIWAN
Dec 19th, 2006, 10:56pm
Hi ,
  I try to use Spectre to run a circuit and got the following messages:
 Error found by spectre during circuit read-in.
     "test.sp" 1: Syntax error in specification of `Fatal'.
 Fatal error found by spectre during circuit read-in.
   "test.sp" 2: SPICE Reader failure; see SPICE Reader
       log file: "test.spplog"
Anyone knows what 's the problem of my spice file ?
Note : I mixed spice and Spectre netlist in one file , and use Bsim2v3 spice model file.
Re: spectre simulation error
Reply #1 - Dec 20th, 2006, 4:45am
That error message seems to indicate that the first line of test.sp starts with "Fatal"
I think Berkeley Spice (and some commercial tools) treat the first line as a comment, even if it doesn't start with "*".  You could try putting a * at the beginning of the first line.  But you should also make sure that your netlist looks right -- maybe the program you used to generate the netlist had a Fatal error, and test.sp contains only the error notice rather than the netlist??
Also, I'm not sure you can mix Spice and Spectre in the same file -- I think you have to split the file and use an include command so you can specify the simulator lang= appropriately for each piece.
Reply #2 - Dec 21st, 2006, 9:45am
Cadence provides a Spice to Spectre translator called spp that is called automatically by spectre when it sees a Spice netlist. I believe the Spice translator is generating a fatal error message that is some how getting into the netlist it is sending to Spectre, and then Spectre is treating the error message as a netlist statement. You might want to run spp stand alone on your netlist and use it to clean up the original Spice netlist. Once it is clean and generates no errors, you can run it through Spectre directly.
Reply #3 - Jan 12th, 2007, 6:06am
In fact I'd recommend a newer spectre version (MMSIM60 or MMSIM61) which can natively read SPICE syntax without needing to go through the spp preprocessor. This is both quicker, has better error reporting, and more thorough.
In IC5141, you can add the +csfe command line switch, and it will invoke the new front-end parser (it was introduced in IC5141, but not made the default).
