Jul 18th, 2024, 4:25am
modeling a NMOS in NWELL capacitor? (Read 5220 times)
bluestatic
Dec 21st, 2006, 1:18am
The NMOS in NWELL cap, from what I know is also called varactor by someone.  I'm trying to utilize such kind of capacitor in a 0.13um logic process while the model file is not provided by the foundry.  So DIY the model (if possible) is necessary.
By checking the varactor model from other process/fab, it seems a "NMOS in NWELL" cap can be modeled by using P-type BSIM model,  as long as the following param is revised , for example:
model PVAR bsim3v3 type=p
+version = 3.2 tnom = 25
+capmod = 3 voffcv = -0.015 k1 = 0.482
+vth0 = -1.33+dPVAR2 acde = 1.0 tox = 2.77E-9+dPVAR1
+toxm = 2.77E-9 nch = 2.77E+17 dskip = no
+binunit = 2 k2=0 kt1=0.08
ends PVAR
If the fab provide normal nmos/pmos BSIM model only(and without further modeling support from them) , is there a safe way to "convert to" a varactor model? How should I modify the BSIM model parameter , ie, which are the vital parameter that I have to know to specify a varactor model?
Thanks for all the help
Re: modeling a NMOS in NWELL capacitor?
Reply #1 - Dec 21st, 2006, 5:46pm
If you DIY the model, how do you get the right number of those parameters, like vth0?
Yawei
greatqs
Reply #2 - Dec 25th, 2006, 3:12am
I think Bsim3v3 model is not as simple as you think.
And it is of no sense if the model itself is not correct, especially for RF
bluestatic wrote on Dec 21st, 2006, 1:18am:
ends PVAR
bluestatic
Reply #3 - Dec 27th, 2006, 2:05am
guys, thanks for the reply.
As you can see that I'm trying to find a internal-relationship between normal PMOS transistor model and the Nmos in NWELL capacitor(which of course kind of risky) .  and someone told me  this kind model could be accurate enough if vth0 and tox is set correctly.  However, I'm not sure about it.
My application is not RF, and in terms of design itself I can tolerate 20% variation.  I'm wondering if someone has experience of handling it with succeful approximation model.
