Sep 17th, 2024, 4:22pm
powerup/down time (Read 1802 times)
dandelion
powerup/down time
Dec 22nd, 2006, 1:08am
I am designing a circuit which is used in the portable handset. I want to do the powerup and powerdown analysis, I wonder what is the rampup and rampdwon time should I select in simulation?
Also, There is also an enable signal in my circuit, which is assumed from the other chip in the system, e.g., a MCU.Same as above, what should I select the rampup and rampdown time should I select to do the enable/disbale analysis?
Re: powerup/down time
Reply #1 - Dec 25th, 2006, 1:43am
The rampup and rampdown time depend on your voltage source, the bypass caps tied on VDD, etc. For simulation, I guess maybe 0.1us is enough. However, it needs very long simulation time if your circuit is very complex.
As the enable signal, I don't think its rise time or fall time are important.
BG
Yawei
