Aug 15th, 2024, 6:48am
Any CDR model by Verilog-A (Read 5522 times)
neoflash
Mixed-Signal
Designer
Dec 24th, 2006, 8:39pm
Hope could view it as reference to write mine, thanks.
Re: Any CDR model by Verilog-A
Reply #1 - Jan 2nd, 2007, 4:22am
What's a CDR?
Frank Wiedmann
Munich, Germany
Reply #2 - Jan 2nd, 2007, 4:55am
Clock and Data Recovery, probably.
jbdavid
Reply #3 - Jan 20th, 2007, 8:26pm
if you can use Verilog-AMS its probably better..
The main trick in my first one was to understand they type of CDR..
so I used a normal PFD for the "lock to reference" phase, when that is locked, the CDR gets a signal, that switches the control to the data channel Phase detector.
The model I have references the design of our IP vendor, so I can't share it. Just these general concepts.
jbdavid
