Jul 18th, 2024, 6:30am
PNP model (Read 6411 times)
uncle_ezra
PNP model
Dec 25th, 2006, 12:29am
I wrote a PNP power transistor model in spectre with the following parameters:
+ IS=1.2545e-14  BF=180  NF=1
+ VAF=68.28 IKF=0.375  ISE=1e-22
+ NE=1.18359  ISC=4.83798e-6
+ RB=0.331  RE=0.233
+TR=1e-8  TF=1e-10
I noticed that the beta of PNP goes negative at high temperature (120C) when the collector current is less than 150mA. Is there anything wrong with my model?
Re: PNP model
Reply #1 - Dec 25th, 2006, 1:22am
Uncle Ezra,
  First reaction, is that ISC seems high, ~1uA, since leakage
doubles every 10C, then the base-collector current at 120C
is several mA. Shouldn't be fatal but it is usual.
uncle_ezra
Re: PNP model
Reply #2 - Dec 25th, 2006, 4:33pm
I see ... well thats the spice parameter ROHM provided for their power transistor and supposely works from -55 to 150C
Re: PNP model
Reply #3 - Dec 26th, 2006, 6:56am
Uncle Ezra,
  Can you share any additional information about how yoy are using the
pnp in your design? When I hook up a pair of PNP transistors as a simple
current mirror, at 120C, the Beta is about 140. It may also be that there
are diferences in the model defaults. Which simulator are you using?
uncle_ezra
Re: PNP model
Reply #4 - Dec 27th, 2006, 12:51am
Basically I am using the PNP (off-chip) as my switch for my LDO design. So I have an opamp followed by a buffer (on-chip) which drives the PNP which then feedbacks to provide 1.8V supply voltage. The reason for not designing the whole regulator on-chip is because of high load current required.
As you said ISC seems high which is causing the beta to flip at high temperature. Not sure how accurate this figure is since I got this from the manufacture spice parameter. If I use the default value from spectre, which is 1e-13, beta is positive. Maybe because it is a power transistor the leakage may be large as compared to a regular PNP transistor.
Re: PNP model
Reply #5 - Dec 28th, 2006, 5:48am
Uncle Ezra,
  There is one thing that is a little confusing about the model, the
forward Is is 1e-22 but the reverse Is is 4.8uA. This indicates a
very small emitter area with a huge collector area. The forward
characteristics don't seem consistent with a power transistor.
So the transistor may need more Vbe than expected.
uncle_ezra
Re: PNP model
Reply #6 - Dec 28th, 2006, 5:02pm
Here is the link to the datasheet http://www.rohm.com/products/databook/tr/pdf/2sa1036k.pdf
Attached is the spice parameter provided by the manufacture
Re: PNP model
Reply #7 - Dec 29th, 2006, 7:51am
Uncle Ezra,
  What is the supply voltage for the LDO? If the pnp does not have enough
headroom, then the beta may have strange values. I did some simulations
and the drop-out voltage is about 0.7 for the transistor, see the attached
plots. BTW, the simulations are for a 1.8V LDO with 100mA of load current
and show the power supply being swept from 2.25V to 3V. The LDO does not
start acting like an LDO until the dropout voltage is greater than about 2.5V.
  Also, my previous remark about it was incorrect. The IS of the transistor is
fine so the scaling should be correct. The low ISE just means that the process
is clean and the transistor has good low current beta.
uncle_ezra
Re: PNP model
Reply #8 - Dec 29th, 2006, 5:34pm
Hello Sheldon,
Thanks, that picture makes sense. I am using a 3.3 V supply for a 1.8V LDO. The simulation just starts to behave strangely at high temperature (>100C) if load current <1mA. Basically higher load current is required at high temperature to ensure sufficient dropout across the pnp.
