Aug 17th, 2024, 11:13pm
Phase Noise in Ring VCO: Process scaling Issue? (Read 1439 times)
neoflash
Mixed-Signal
Designer
Dec 26th, 2006, 4:54am
Hi:
There is rumor saying that with the process going from .18 to .13 and 90nm, device noise is getting more and more severe in ring VCO design.
Previously,  i guess that is .18um era, it is said that ring VCO design does not require a lot art to have low jitter. For 1GHz qudature CMOS ring VCO, it is easy to have jitter as low as 3ps (rms).
However, when I start to do some real work on 90nm, the phase noise is so huge that I can not skip huge passive noise filter and still have high timing jitter.
So, i hope those experienced designers in this field could comment on this trend.
Neoflash
