Aug 17th, 2024, 3:25pm
Potential Errata List of "High-Purity Oscillator" (Read 2019 times)
neoflash
Mixed-Signal
Designer
Dec 31st, 2006, 7:01am
P46:
Equation (23) should not contain "()" in last "[]" item.  The sign of item jCw_ is inverse.
P57:
"scaling the output noise by the loss tank" should be "scaling the output noise by the lossless tank".
P109:
"phase noise is lower than that with a larger W/L" should be "phase noise is lower than that with a smaller W/L".
P157:
Equation (52) does not make sense.
P183:
Equation (15) is not correct. E(t) should have a "-" sign instead of "+".
Some of them might be fake issue, but i hope it helps to polish next edition. Anyway, it is good for get a full view of LC-VCO.
emad
Cairo, Egypt
Re: Potential Errata List of "High-Purity Oscillat
Reply #1 - Dec 31st, 2006, 11:48pm
First, I thank you for the meticulous review.
I read the comments and my quick response is that I accept your comment on the typo on page 109 and I also accept your comment about the error in equation (15) page 183. However, I should note that this sign error in eqn(15),pp 183 does not propagate any further. The remaining analysis does not use this equation and hence does not carry the same mistake.
As for the remaining comments, I referred them to my co-author Jacob Rael for evaluation and comment.
Thanks once again. We will form the errata and post it to the book page on Designers-Guide.
Emad
