Aug 17th, 2024, 11:21am
Purpose of this resistor in LC-VCO (Read 2328 times)
neoflash
Mixed-Signal
Designer
Jan 01st, 2007, 12:55am
Why there is a 2.5k ohm resistor on the control line?
What is that for?
ACWWong
Oxford, UK
Re: Purpose of this resistor in LC-VCO
Reply #1 - Jan 1st, 2007, 4:33am
There are couple of reasons depending on the nature of the control line signal.
If the control lines signal is an analogue tuning voltage, then the 2.5kohm forms a high frequency pole for the tuning line and part therefore is part of the loop filter. It also acts as ESD robustness (the, especially if the control line goes to a pad/external world.
If the control line is digital and used to either completely switch in/out the FETs in switched tank structure, then again the resistor adds ESD robustness, and acts to attenuate noise on the control line.
cheers
aw
rf-design
Reiner Franke
Reply #2 - Jan 5th, 2007, 3:03am
I share the first view from the first comment
1. Possible additional pole in the loop transfer function which make a third order PLL. The question is that for the same phase delay at the critical loop bandwidth frequency this could be more efficient be done by an multi-stage RC filter.
2. Do not short the second harmonic current in the loop filter cap. This could possible be a negative effect for PN.
3. Isolating noise from the digital control is more effective by using a buffer inverter which is conneted to clean supply. So questionable!
