Daniel_Platte
Munich/Germany
Hi all!
The VHDL-AMS language provides a feature "Procedural Simultaneous Statement" that is basically the same as Verilog-AMS's "Procedural Assignment". Unfortunately, AMS Designer and ADvance MS do not support the procedural simultaneous statement :'(.
Example (from a diode model): --------------------------------------- BEGIN CODE SNIPPET --------------------------------------------------------
PROCEDURAL IS BEGIN VD := VIN-VOUT-IIN*RS/AREA; ID := GMIN*VD+AREA*(ISS*(-1.0+exp(0.181069E-2*VD*Q/K))-IBV*exp((-0.333167E-2)*(BV+VD)* Q/K)); CJ := AREA*CJO*iffunc1(VD); END PROCEDURAL;
--------------------------------------- END CODE SNIPPET --------------------------------------------------------
The VHDL-AMS committee proposes to model this by using analog functions like this:
TYPE QR IS RECORD VDv : REAL; IDv : REAL; CJv : REAL; END RECORD;
FUNCTION proceqs( VINi : REAL; IINi : REAL; VOUTi : REAL; IOUTi : REAL; VDi : REAL; IDi : REAL; CJi : REAL; dIDdti : REAL; dVDdti : REAL ) RETURN QR IS VARIABLE VINv : REAL := VINi; VARIABLE IINv : REAL := IINi; VARIABLE VOUTv : REAL := VOUTi; VARIABLE IOUTv : REAL := IOUTi; VARIABLE VDv : REAL := VDi; VARIABLE IDv : REAL := IDi; VARIABLE CJv : REAL := CJi; VARIABLE dIDdtv : REAL := dIDdti; VARIABLE dVDdtv : REAL := dVDdti; BEGIN VDv := VINv-VOUTv-IINv*RS/AREA; IDv := GMIN*VDv+AREA*(ISS*(-1.0+exp(0.181069E-2*VDv*Q/K))-IBV*exp((-0.333167E-2)*(BV+VD v)*Q/K)); CJv := AREA*CJO*iffunc1(VDv); RETURN (vdv, idv, cjv); END;
(VD, ID, CJ) == proceqs(VIN, IIN, VOUT, IOUT, VD, ID, CJ, dIDdt, dVDdt) TOLERANCE "Current";
Unfortunately, the topology checker of AMS Designer counts this simultaneous statement as one equation (instead of three) and refuses to simulate the model...
Does anyone have experience how to work-around this problem? Are there simulators supporting the proc. sim. stat. or plans to realize the language construct?
Thanks in advance for any help.
Cheers, Daniel
P.S. Complete VHDL-AMS code is attached
