hi everyone,
im undergraduate student and hving some questions related sigma delta modulator in dolphin SMASH. The coding shown below was having some errors which im not able to solve:>>> VHDL
/* combine */
LIBRARY IEEE;
use IEEE.MATH_REAL.all;
use IEEE.STD_LOGIC_1164.all;
use IEEE.ELECTRICAL_SYSTEMS.all;
USE work.all;
entity sdm_1 is
PORT(
TERMINAL vin : ELECTRICAL;
SIGNAL clk : IN STD_LOGIC;
SIGNAL op : OUT STD_LOGIC);
END sdm_1;
ARCHITECTURE simple OF sdm_1 IS
TERMINAL adder2o : ELECTRICAL;
TERMINAL intero : ELECTRICAL;
SIGNAL Qo : STD_LOGIC;
TERMINAL DACo : ELECTRICAL;
BEGIN
adder_1 : entity ADDER(simple)
GENERIC MAP(A => 1.0,B => -1.0)
PORT MAP(ip1 => vin,ip2 => DACo,op =>adder2o);
inter_1 : entity inter(simple)
PORT MAP(ip => adder2o,op =>intero);
Q : entity quantizer(simple)
GENERIC MAP(threshod => 0.0)
PORT MAP(clk => clk,ip => intero,op => Qo);
DAC_1 : entity DAC(simple)
GENERIC MAP(mx => 5.0,mn => -5.0)
PORT MAP(ip => Qo,op => DACo);
op <= Qo;
END simple;
library IEEE;
use ieee.math_real.all;
use ieee.std_logic_1164.all;
USE work.all;
entity top_circuit is
end top_circuit;
architecture test of top_circuit is
terminal A : electrical;
quantity xin across iin through A to electrical_ref;
signal op : std_logic;
signal clk : std_logic;
begin
m_sdm3 : entity sdm_1(simple)
port map(vin => A,clk =>clk,op => op);
xin == 5.0*sin(math_2_pi*1.0e6*NOW);
process
begin
clk <= '1';
wait for 500 ps;
clk <= '0';
wait for 500 ps;
end process;
end test;
integrator sub-block--7. Integrator --
--Used as an integrator for Sigma-Delta Converters --
LIBRARY IEEE;
USE IEEE.MATH_REAL.ALL;
use ieee.math_complex.all;
USE IEEE.ELECTRICAL_SYSTEMS.ALL;
use IEEE.STD_LOGIC_signed.all;
use IEEE.STD_LOGIC_arith.all;
ENTITY inter is
PORT(TERMINAL ip : ELECTRICAL;
TERMINAL op : ELECTRICAL);
END inter;
ARCHITECTURE simple OF inter IS
QUANTITY vop ACROSS iop THROUGH op TO ELECTRICAL_REF;
QUANTITY vip ACROSS ip TO ELECTRICAL_REF;
BEGIN
vop == vip'integ;
END simple;
PAT file--
.VHDL SET KIND=AMS
.VHDL elaborate entity=top_circuit unit=test
.VHDL compile library=work source=adder.vhd
.VHDL compile library=work source=dac.vhd
.VHDL compile library=work source=inter.vhd
.VHDL compile library=work source=quantizer.vhd
error found--
Compiling Entity Declaration INTER
Compiling Architecture SIMPLE of INTER
Compiling Entity Declaration SDM_1
Compiling Architecture SIMPLE of SDM_1
Compiling Entity Declaration TOP_CIRCUIT
Compiling Architecture TEST of TOP_CIRCUIT
Creating library file: libwork_inter.a
Creating library file: libwork_sdm_1.a
Creating library file: libwork_top_circuit.a
work_inter_simple.cpp: In member function `short int WORK::INTER_SIMPLE::AmsBim(long int, TRANS_PARAM_BIM*)':
work_inter_simple.cpp:390: error: `VIP_INTEG_INTEG_q6_row' was not declared in this scope
ERROR: unable to compile work_inter_simple.cpp
Creating library file: libwork_sdm_1_simple.a
Creating library file: libwork_top_circuit_test.a
im so frustrated and cant solve the problem, can anyone help me? thx a million... regards, seamus
