ACWWong wrote on Jan 8th, 2007, 3:40pm:Yes, generally MOS devices in two stage opamps are biased in saturation. Major reasons are good output impedance, historic, saturation is a relatively well defined operating condition etc.
But there are many (albeit minority) cases, especially at low power and low voltage, where MOS devices in opamps may not be biased in saturation (i.e in weak inversion, triode etc.).
So it might not be completely safe to assume all devices in any MOS opamp schematic are in saturation.
cheers
aw
Hi AW,
I notice with interest how you demarcate "saturation" from "weak inversion". I would say that the two are not mutually exclusive. In fact, if you
are designing opamps for high Gm (obviously), then the input devices of the opamp are unlikely to be in strong inversion as the Gm of a MOS is quite
poor in really strong inversion but gets better towards moderate and weak inversion. So, for switched-cap applications, your opamp probably has input
devices which are in saturation but also in moderate inversion. The only circuits where one might want to really bias all opamps in truly strong inversion might be high-speed continuous-time circuits where slewing is not allowed in the opamp.
I would suggest that we all be more careful about not mixing up saturation and linear region with strong inversion and weak inversion.
Vivek
