May 15th, 2024, 10:56am
RESIZE CONTATS & VIAS (Read 4922 times)
Jan 09th, 2007, 12:25am
Hi, Guys,
I am transplanting a layout of an analog circuit from one fabrication factory (UMC 0.18um ) to another fabrication factory (TSMC 0.18um ).
The sizes of their contact and vias are different. How can I resize the sizes of the contact and vias of the old process (UMC 0.18um) to the sizes of new process (TSMC 0.18um ) automatically ?
The layout tool is Virtuoso.
BG
Yawei
bernd
Munich/Germany
Re: RESIZE CONTATS & VIAS
Reply #1 - Jan 9th, 2007, 8:29am
How do you do that?
If you use contacts defined in your technology library as so called
'symbolics' you can dump and edit the technology file of that library
and redefine the contacts to the new size and reload/compile the modified technolgy file to your library.
The tech file section is called 'symContactDevice'.
Bernd
Just another lonesome cad guy
Reply #2 - Jan 10th, 2007, 5:50pm
Bernd,
We have an ADC design silicon-provened using UMC 0.18um technology. Now we need target it to TSMC 0.18um technology. Smiley Sure the simulation is done.
Your suggestion is great. It works well. Thank you.
Yawei
Reply #3 - Jan 15th, 2007, 1:17am
I found some contacts in the transistors that instantiated from the PDK. They were not resized when I modifiied the technology file as Bernd said. Can I modifiy the technology file and resize the contact in those transistors?
Yawei
haikom
Reply #4 - Mar 24th, 2007, 1:57pm
I'm not 100% sure, but I think the vias in the device are defined inside the pcell definition, isn't ist? If yes, you have to modify the pcell source code.
haikom
View Profile haikomo   IP Logged
