Aug 16th, 2024, 7:17pm
kT/C noise in passive mixers (Read 4902 times)
carlgrace
Berkeley, CA
Jan 09th, 2007, 11:10am
I am looking into switch-mode passive mixers and I've read most of the relevant papers.  I am wondering, though, why isn't the output thermal noise density determined by kT/C noise of the sampling switch.  It seems to me that there would be a lot of output noise because the reverse-biased diode formed my the drain diffusion of the MOS switch would sample the switch noise.  This noise would be very high because the diffusion capacitance would be rather small.  It seems from the papers, however, that this is not the case.  Can anyone give me an intuitive explanation of why the output noise of the passive mixer isn't kT/C, where C is the parasitic capacitance of the drain diffusion?
thanks,
Carl
Re: kT/C noise in passive mixers
Reply #1 - Jan 9th, 2007, 4:05pm
kt/C noise is for sampling processes. passive mixers do not sample.
carlgrace
Berkeley, CA
Reply #2 - Jan 10th, 2007, 7:27am
Ken,
Say that you are driving the switches with a less that 50% duty cycle clock.  Then there are time slots where there is no resistive connection between the LNA and the VGA.  In this case wouldn't you say the passive mixer is sampling?  I imagine you would put a large filter cap at the IF port of the mixer, and that could lower the noise, but I am confused about this.  I would think that during the time when all switches are OFF, the filter cap would be holding a sample of the rf input voltage.  Am I totally off base here?
Carl
Reply #3 - Jan 10th, 2007, 9:27am
I was assuming a full wave bridge passive mixer. If you are using a track and hold as a mixer then kt/C noise would apply.
mg777
Reply #4 - Jan 14th, 2007, 12:56pm
Take thermal noise across a resistor R with a parasitic shunt capacitance C. The mean squared noise voltage is then 4kTR*(1/2piRC) so the R cancels and you get kT/C. You can integrate over the pole, it'll add some pi type factor from the tan^-1 function, that's all.
Point then is that even without sampling you get kT/C - sampling is just one form of integration. It may seem funny that the resistor is the source of the noise but its value disappears from the answer. Doesn't contradict the fluctuation-dissipation theorem in any way, though. The dissipation remains the mechanism for the system to remain in thermal equilibrium.
M.G.Rajan
www.eecalc.com
Reply #5 - Jan 14th, 2007, 11:37pm
Yes of course. My mistake.
Croaker
Reply #6 - Jan 15th, 2007, 4:33am
Well, the low frequency portion of the PSD increases with R, but the 3db pole decreases with R.  The increased low frequency noise is choked out and the RMS noise is independent of R.
mg777 wrote on Jan 14th, 2007, 12:56pm:
M.G.Rajan
www.eecalc.com
