robertosung
Hi, I have a verilog-A code that runs on unix version of hspice. But it doesn't run in windows xp even though I have the hsp-vacomp license. The file name is tx_datagen.va and it complains that tx_datagen.cml is not found. SO I tried to compile it in the command prompt window.
hsp-vacomp -V 2 -W 2 -I ..\ -o tx_datagen.cml -M tx_datagen.va
It gave me the following warnings
Warning: module 'tx_datagen', memory state: 'sd_future'
to all of the following variables
real voutodd, voutoddnext, voutodd_1; real voutoddb, voutoddbnext, voutoddb_1; real voutoddlead, voutoddlag, voutoddlead_1, voutoddlag_1; real voutoddblead, voutoddblag, voutoddblead_1, voutoddblag_1; real sd_past, sd_now, sd_future; real tap111lead, tap111lag, tap110lead, tap110lag; real tap101lead, tap101lag, tap100lead, tap100lag; real tap011lead, tap011lag, tap010lead, tap010lag; real tap001lead, tap001lag, tap000lead, tap000lag; Is there a syntax change between the two operating systems?
Thanks in advance
