Jul 16th, 2024, 2:33pm
piecewise source realization (Read 3666 times)
Pavel
Lausanne/Switzerland
Jan 15th, 2007, 1:28am
Hello
I have convergence problem with picewise voltage source.
Here is my code:
module SUPPLY_SRC (OUT);
output OUT;
voltage OUT;
parameter real t1 = 1m, 	t2 = 2m,	t3 = 5m,	t4 = 7m,	t5 = 10m;
parameter real v1 = 0.0,	v2 = 3.0, 	v3 = 3.0,	v4 = 0.0,	v5 = 0.0;
real offset, slope, a0;
analog begin
	@(initial_step) begin
		offset = 0.0;
		slope = 0.0;
		a0 = 0.0;
	@(timer(t1)) begin
		slope = (v2-v1)/(t2-t1);
		offset = $abstime;
		a0 = V(OUT);
		$discontinuity(1);
	@(timer(t2)) begin
		slope = (v3-v2)/(t3-t2);
		offset = $abstime;
		a0 = V(OUT);
		$discontinuity(1);
	@(timer(t3)) begin
		slope = (v4-v3)/(t4-t3);
		offset = $abstime;
		a0 = V(OUT);
		$discontinuity(1);
	@(timer(t4)) begin
		slope = (v5-v4)/(t5-t4);
		offset = $abstime;
		a0 = V(OUT);
		$discontinuity(1);
	V(OUT) <+ a0 + slope*($abstime - offset);
Simulation reach 1ms, and then convergence error appears:
Error found by spectre at time = 1 ms during transient analysis `amsAnalysis'.
   Matrix is singular (detected at `TB.U1:AUT_flow' and `TB.vdd').
Solution at last successful step (at 1 ms), and last Newton iteration (at 1
       ms):
   I(TB.U1:AUT_flow): 0 A              0 A
   V(TB.vdd): 0 V              0 V
Analysis `amsAnalysis' terminated prematurely due to error.
ncsim: *E,RNALER: Simulation terminated due to analog error.
When I change contibution expression
to be as follows
V(OUT) <+ slope*($abstime - offset);
simulation terminates, but the signal form isn't what I need.
For discontinuity function I used 1 as argument because it's 1st derivative that breakes, not signal itself.
Am I rigtht in my supposition and what could be a reason of such error?
Thank you in advance.
Pavel.
P.S. In error message I changed intentionnally the name of signal from OUT to AUT, otherwise smily appears intstead: ShockedUT.
Re: piecewise source realization
Reply #1 - Jan 15th, 2007, 5:16am
I think you're giving yourself trouble by setting a0 = V(OUT) and then trying to use this value as part of the contribution V(OUT)<+.
Can you compute a0 from the v's?
Pavel
Reply #2 - Jan 15th, 2007, 7:32am
Geoffrey,
The reason of error was exactly as you supposed.
I changed for the following
	@(timer(t1)) begin
		offset = $abstime;
		a0 = v1;
		$discontinuity(0);
	@(timer(t2)) begin
		offset = $abstime;
		a0 = v2;
		$discontinuity(0);
and now it works as I want.
Thanks  [smiley=dankk2.gif]
Pavel.
Reply #3 - Jan 15th, 2007, 10:28am
The problem was that whenever one of your timer function fired, you set a0 = V(out), and so in the final contribution statement you effectively ended up being
   V(OUT) <+ V(OUT) + slope*($abstime - offset);
Verilog-A treats contributions as equations rather than assignments, so in a mathematical sense you had
   V(OUT) = V(OUT) + slope*($abstime - offset)
You can now subtract V(OUT) from both sides to give
   0 = slope*($abstime - offset)
Notice that this is nonsensical because it does not contain anything that can be solved for to make it true. Also notice that the output of the source is effectively left unspecified. What you wanted to do was to base the current output voltage on a previous output voltage, but what you did was to base it on the current output voltage at those times when the timer functions fired.
Pavel
Reply #4 - Jan 16th, 2007, 4:51am
Ok, Ken. I understood my mistake.
Thanks.  [smiley=dankk2.gif]
Pavel.
