Geoffrey, thank you for your response.
Here is shorted part of my code:
module_A:
Code:module_A (COIL1, COIL2, COIL1_ext, COIL2_ext);
output COIL1, COIL2;
input COIL1_ext, COIL2_ext, node_read;
electrical COIL1, COIL2;
electrical COIL1_ext, COIL2_ext;
analog begin
dOut_int = ddt(I(COIL1, node_read));
dOut_ext = ddt(I(COIL1_ext, COIL2_ext));
V(COIL1, node_read) <+ l_ant_reader * dOut_int + M * dOut_ext;
module_B:
input COIL1_ext, COIL2_ext;
analog begin
dOut_int = ddt(I(COIL1, node_tag));
V(COIL1, node_tag) <+ l_ant_tag * dOut_int + M * dOut_ext;
Assembly
Code:module_TOP ();
ground gnd;
module_A U1 (.COIL1(coil1_A), .COIL2(gnd), .COIL1_ext(coil1_B), .COIL2_ext(gnd));
module_B U2 (.COIL1(coil1_B), .COIL2(gnd), .COIL1_ext(coil1_A), .COIL2_ext(gnd));
For simplicity I didn't show signal source (in module_A) and some other circuitry in modules A and B,
concentrating only on inductive coupling.
I also changed ground strategy, declaring ground only in TOP module.
This changement didn't resolve the problem.
Signal
coil1_A as well as
COIL1 output of
module_A are at 0. When I deconnect
module_B they return to "normal".
Regards.
Pavel.
