Aug 15th, 2024, 10:51am
porting verilog-A code from unix to windows in hsp (Read 3341 times)
robertosung
Jan 09th, 2007, 6:54pm
I have a verilog-A code that runs on unix version of hspice. But it doesn't run in
windows xp even though I have the hsp-vacomp license. The file name is
tx_datagen.va and it complains that tx_datagen.cml is not found. SO I tried
to compile it in the command prompt window.
hsp-vacomp -V 2 -W 2 -I ..\ -o tx_datagen.cml -M tx_datagen.va
It gave me the following warnings
Warning: module 'tx_datagen', memory state: 'sd_future'
to all of the following variables
  real voutodd,       voutoddnext,   voutodd_1;
  real voutoddb,      voutoddbnext,  voutoddb_1;
  real voutoddlead,   voutoddlag,    voutoddlead_1,   voutoddlag_1;
  real voutoddblead,  voutoddblag,   voutoddblead_1,  voutoddblag_1;
  real sd_past,       sd_now,        sd_future;
  real tap111lead,    tap111lag,     tap110lead,      tap110lag;
  real tap101lead,    tap101lag,     tap100lead,      tap100lag;
  real tap011lead,    tap011lag,     tap010lead,      tap010lag;
  real tap001lead,    tap001lag,     tap000lead,      tap000lag;
Is there a syntax change between the two operating systems?
Thanks in advance
Re: porting verilog-A code from unix to windows in
Reply #1 - Jan 10th, 2007, 10:04am
Do you have the same version of HSpice installed on both platforms?  It sounds like maybe you have a newer (smarter) version installed on unix.
robertosung
Reply #2 - Jan 10th, 2007, 11:56am
Actuall, I am using the same hspice version in both unix and windows which is
2006.09
It doesn't give any errors other than the warnings about memory state.
But it doesn't generate a cml file.
Thanks, Roberto
Reply #3 - Jan 11th, 2007, 4:02am
I've never used HSpice on Windows, so I can't help much.  Just a few thoughts.
Does the .val (verilog-a log) say anything?
Have you ever successfully compiled a VA model on Windows?  Does it usually put them in a model-cache directory?  Is there anything there, and/or is the directory writable?  Do you have all the `include files (disciplines.vams, constants.vams)?
