Sep 30th, 2024, 4:28pm
any ideal opamp block? (Read 4456 times)
topquark
Thames Valley, UK
Jan 11th, 2007, 2:40am
Hello folks,
I am doing a preliminary switched cap block-level simulation. For this I need to build an ideal integrator.
I thought the "opamp" instance from ahdlLib would do the job with a feedback cap.
But, it isn't working  !  :-/
Infact, i tried to do an inverting amp with that block(V+=Vdd, V-=gnd!, Vref=?), the tran simulation goes fine but opamp just doesn't work as it should!
Anything I'm missing?
What should I connect to the Vref pin?
Any pointers please?
Gau
Re: any ideal opamp block?
Reply #1 - Jan 11th, 2007, 8:27am
You might consider using the ideal opamp model given on the Verilog-AMS page: http://www.designers-guide.org/VerilogAMS/basic-models/ideal-opamp/ideal-opamp.v....
avlsi
singapore
Reply #2 - Jan 23rd, 2007, 2:50am
Hi , you can use VOtlage controlled VOltage source (VCVS). This is a good way to use ideal opamp. I am using this in my design.
Winners never Quit,Quitters never Win
smarty
Reply #3 - Apr 24th, 2007, 9:29am
 I think, the ref node in ideal op amp is the Analog ground (kindly correct me if I am wrong).
I have used this model from analogLib.
eg. Y1 OPAMP2 INP INN OUT AGND
Cheers,
SBR
View Profile smarty smarty   IP Logged
adesign
Reply #4 - Apr 25th, 2007, 9:44pm
You can give a try with mgcLib available in Design Kits.
Julian18
Reply #5 - Apr 29th, 2007, 2:08am
HI,if u are using hspice, u may just put
     Eopamp 1 2   OPAMP 3 4
where 1 and 2 is the output  port (1:+   2:-  ), while 3  4 is the input port(3:+  4:-  ).  make sure u do not mistype the order.
Best Regards
Julian
