Sep 17th, 2024, 2:24pm
Verilog-A model for comparator (Read 1176 times)
cat18521
Jan 11th, 2007, 7:42am
I am a student in the university and now I'm designing the comparator part of a SAR-ADC.The comparator consists of 3 stages preamplifiers and a regenerative latch.I want to use verilog-a to do it.But I am confused about a thing that whether I should write the verilog-a models for the 3 preamplifiers and the latch and then combine them together or only write a model for the comparator?
If anyone have the verilog-a model for the preamplifier and the latch, can you please send it to me, cause I'm a new bird about the verilog-a.
Thanks a lot!!
my email:  ronaldomiao@yahoo.com.cn
Re: Verilog-A model for comparator
Reply #1 - Jan 11th, 2007, 8:34am
In general you should write a combined model unless there is some compelling reason for writing separate models and combining them. You do this because it is generally easier to write one model rather than several, and the single model generally runs considerably faster.
Also, it is best if people post any models they might have to this website rather than sending it directly to you so everyone can benefit.
A comparator model is given on the Verilog-AMS page: http://www.designers-guide.org/VerilogAMS/.
cat18521
Reply #2 - Jan 11th, 2007, 2:24pm
to Ken:thank you for your reply!
I have downloaded the comparator model from the webpage you gave.But I find that it is rather too simple.
and many parameters are not included in that model.The comparator I need should have differential input(ip,in)
,differential output(outp,outn),reset signal and clock signal. I have write some code for my preamplifier and latch,
but I am not sure about its correctness.Also, I don't know how to add clock signal into the model and how to define the active time for each stage of the preamplifiers.
If you know ,please give me some advice! Thanks
My preamplifier code:
// VerilogA for addaLabs, cmp, veriloga
`include "constants.vams"
`include "disciplines.vams"
module cmp (ip, in, outp, outn, reset);
inout   ip, in, outp, outn, reset;
electrical   ip, in, outp, outn, reset;
parameter vo  =  0;  // output offset voltage
parameter tr  =  1n; // rise time
parameter tf  =  1n; // fall time
parameter Vt  =  0;  // threshold voltage
parameter Vdd =  3;  // supply voltage
parameter td  = 1n;  // threshold voltage
parameter cm_voltage = 0;
parameter gain = 10;
real voutp, voutn;
analog
begin
     if (V(reset) > 0.5)
        voutp = cm_voltage;
     else if ( (V(ip) - cm_voltage) > Vt )
        voutp = (V(ip) - V(in)) * gain;
     else
     if (V(reset) > 0.5)
        voutn = cm_voltage;
     else if ( (V(in) - cm_voltage) > Vt )
        voutn = (V(in) - V(ip)) * gain;
     else
 V(outp) <+ transition (voutp, td, tr, tf);
 V(outn) <+ transition (voutn, td, tr, tf);
My latch code:
// VerilogA for addaLabs, ADClatch, veriloga
module ADClatch (in, out, reset);
inout in, reset, out;
electrical in, reset, out;
parameter gain = 1000000; // 1EXP+06
parameter   rt = 1n     ; // risetime, default = 1 ns
parameter  td = 1n;
parameter vdd = 3;
parameter vss = -3;
real vout;
analog
begin
   if (V(reset) > 0.5)
      vout = cm_voltage;
   else if (V(in) * gain > vdd)
      vout = vdd;
   else if (V(in) * gain < vss)
      vout = vss;
   else
      vout = V(in) * gain;    // V(in) could be positive or negative
  V(out) <+ transition (vout, td, rt, rt);
