Jul 17th, 2024, 4:27pm
What does Pad Ring Used for? (Read 1743 times)
qiushidaren
I am a lovely
MOSFET!
Chengdu
Jan 11th, 2007, 6:56pm
In Dolphin’s Virtual Component specification, I find some pads have pad rings, but I don’t know what does pad ring used for, cuz I haven’t heard of “pad ring” before. Can someone explain it for me?
Terry
Croaker
Re: What does Pad Ring Used for?
Reply #1 - Jan 12th, 2007, 8:49am
Pad can either refer to the bonding pad or the entire IO circuit.  The pad ring is the entire ring of IO circuits that goes around the chip.  If you're saying there's a pad ring in your pad circuit, I guess you might be referring to some metal that is used to link up adjacent pads and distribute vdd/gnd.
There are also guard rings used for isolation of transistors and there's a seal ring that goes around the chip to mechanically stabilize it.
« Last Edit: Jan 12th, 2007, 11:10am by Croaker »
