Jul 19th, 2024, 10:14pm
how to convert spectre netlist to hspice netlist (Read 6165 times)
jobless
India
Jan 12th, 2007, 5:51am
is there a way to convert spectre netlist into hspice ?
Re: how to convert spectre netlist to hspice netli
Reply #1 - Jan 12th, 2007, 5:57am
The easiest way would be to write a perl script, but in IC610, you could use File->Import->SPICE (I think that's the menu) which can create a real schematic from a spectre netlist, and then you could netlist that in the hspiceD interface in ADE.
simon2
Southampton, United Kingdom.
Reply #2 - Sep 20th, 2007, 4:29pm
... try this in Wordpad (although for some search and replace functions, Word might be better)
***      Spectre            to       Hspice
***      \                                <return> +
***      Inn                              Xnn
***      subckt                        .sub
***      ends                          .ends
***      resistor r=                  (empty)
***      capacitor c=               (empty)
***      sa, sb, sca, scb           (comment out)      NB: ignored in Spectre & Hspice
***      scc in MOS                  (comment out)      NB: ignored in Spectre & Hspice
***      (Vdc3/2)                     'Vdc3/2'                 brackets ( ) to single quotes ' '
***      Rnn n1 n2 rppolywo     XRnn n1 n2 rppolywo
You may have to write a subckt for XRnn depending on the foundry model files you are using.
I find the above covers most cases.
Cheers,
           SimonH.
Simon.Harpham@ieee.org
http://www.SiliconDevices.com
