simon2
Southampton, United Kingdom.
... try this in Wordpad (although for some search and replace functions, Word might be better)
*************************************************************************** *** Spectre to Hspice *** // ** *** \ <return> + *** Inn Xnn *** subckt .sub *** ends .ends *** resistor r= (empty) *** capacitor c= (empty) *** sa, sb, sca, scb (comment out) NB: ignored in Spectre & Hspice *** scc in MOS (comment out) NB: ignored in Spectre & Hspice *** (Vdc3/2) 'Vdc3/2' brackets ( ) to single quotes ' ' *** Rnn n1 n2 rppolywo XRnn n1 n2 rppolywo ***************************************************************************
You may have to write a subckt for XRnn depending on the foundry model files you are using.
I find the above covers most cases.
Cheers, SimonH.
