Jul 17th, 2024, 6:15am
HSPICE writing .print results to file (Read 3474 times)
Alm
Jan 12th, 2007, 7:43am
Is there a way for getting HSPICE to write the .print results to a file instead of on the screen?
If I simply write hspice file1.spice > out1.spice the entire output including spice netlist, model files get written. I want to avoid that and only write the results obtained using .PRINT statement. ie .print V(I2)
If the above is not possible, is the only possible option to get the entire out file and write some scripts to pick up the relevant information?
Alm
Re: HSPICE writing .print results to file
Reply #1 - Jan 12th, 2007, 7:59am
There's .OPTIONS NOMOD that suppresses playback of the model cards (available even in Spice3f5).
One simulator I worked with had .OPTIONS BRIEF that would turn off everything until .OPTIONS BRIEF=0 was encountered, don't know if it works in HSpice.
Alm
Reply #2 - Jan 12th, 2007, 8:11am
Thanks.
That suppress almost everything except the operating point information. Any way to suppress that too?
-Alm
