Jul 17th, 2024, 6:29am
How to simulate circuit with my own inductors? (Read 7732 times)
zhangjerome
Jan 16th, 2007, 7:32pm
Now I have the S parameters of my own inductors. I want to simulate a circuit with these inductors as matching elements.
So how to incorporate these inductors with other circuit component in Spectre?
Thanks.
Re: How to simulate circuit with my own inductors?
Reply #1 - Jan 16th, 2007, 10:27pm
zhangjerome
Reply #2 - Jan 17th, 2007, 6:04am
Thank you, Ken~~
zhangjerome
Reply #3 - Jan 17th, 2007, 4:51pm
Here are some other questions.
1)How to translate the S parameters into a physically equivalent  circuit? I will use the Pi model for the inductor. How to get the component parameters to describe the inductors?Any references related to this issue?
2)Can circuit simulator derive the inductor's DC characteristics from S parameters? I use this inductor as a degeneration element, so the DC operating point is influenced by the inductor.
3) How to simulate a netlist with Spectre? Just netlist, without schematic.
Thanks~~~
« Last Edit: Jan 17th, 2007, 7:19pm by zhangjerome »
OldHouseBlues
Massachusetts, USA, Earth
Reply #4 - Jan 17th, 2007, 7:21pm
Looks like Sigrity may offer a tool for your item 1),
Broadband SPICE, http://www.sigrity.com/products/bds/bds.htm
zhangjerome
Reply #5 - Jan 18th, 2007, 2:49am
OldHouseBlues wrote on Jan 17th, 2007, 7:21pm:
Does Spectre provide such tools??
Thank you ~~~
Reply #6 - Jan 18th, 2007, 4:18am
zhangjerome wrote on Jan 17th, 2007, 4:51pm:
Depending on the frequency range of your S parameter data, you may or may not get an accurate answer for dc ...
Make sure spectre is in your path and just call it with the netlist as the argument.
OldHouseBlues
Reply #7 - Jan 18th, 2007, 6:06am
zhangjerome wrote on Jan 18th, 2007, 2:49am:
Thank you ~~~
My brief search of the documentation leads me to say "no". Perhaps you can
find time to perform a thorough search and/or wait for an authoritative reply
from more senior members of this community.
Reply #8 - Jan 18th, 2007, 8:10am
Zhang,
 You can use Model Trainer in VPCM to generate an equivalent
circuit for your inductor from s-parameter data, assuming the
data is in Touchstone format. However, why don't you just
use the n-port, that is why it is there?
zhangjerome
Reply #9 - Jan 18th, 2007, 4:26pm
Sheldon:
I have no ided about whether or not the S parameters can give a accurate representation about DC characteristics. With a
equivalent circuit, maybe it's more clear how the inductor will influence the circuit's operating point. I am just trying different
ways.
Jerome Zhang
