Jul 17th, 2024, 4:39am
MOS parameters in Spectre tools Result Browser (Read 2631 times)
zhangjerome
Jan 21st, 2007, 6:37pm
In dcOpInfo-info, A MOS device has parameters such as Cbb cbd cbg cbs cdb...There are parasitic capacitances from each node to all of the nodes. Generally we need Cgs to calculate the gate parasitic capacitance. But now we have Cgs/Csg. So I am confused. To calculate the node capacitance, we should use Cgs or Csg, or the sum of them??
Re: MOS parameters in Spectre tools Result Browser
Reply #1 - Jan 22nd, 2007, 3:58am
There are quite a few posts asking similar questions (also asking about the fact that some of these parameters (which are partial derivitives with the bsim3v3 model) are negative). I suggest using the search capability of this forum to find your answer...
zhangjerome
Reply #2 - Jan 22nd, 2007, 5:48pm
Hi, Beckett:
Thanks for your reply. I checked some related posts. So is it ture to say that the capacitances  calculated by Spectre are in fact not physically exsit and  I can't use Cgs /Cgd to evaluate the gate and drain capacitance??
Thank you again.
Jerome Zhang
