Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Aug 15
th
, 2024, 1:24pm
Home
Help
Search
Login
Register
PM to admin
Design
Analog Design
› common mode input of swit-cap amplifier
Previous topic
Next topic
common mode input of swit-cap amplifier (Read 2016 times)
Steve_IC
Jan 17
th
, 2007, 8:40am
Please see the attached circuit.
I was struglling to set up the common mode input dc level of switcap gain circuit. Most of the cuitcuit analysis just give the ac analysis. I intended to set up the bias through M1 and M3, but it doesn't work. any suggestions?
IP Logged
wuyuchun
Re: common mode input of swit-cap amplifier
Reply #1 -
Jan 18
th
, 2007, 9:56pm
I guess the voltage at c,d and the input and output common voltage are not the same as the voltage at a,b.If so,the results are reasonable.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
»» Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
