Jul 16th, 2024, 10:54am
noiseless mixer has 3db NF? (Read 7396 times)
Jochen
Nuremberg, Germany
Jan 18th, 2007, 7:59am
Dear all,
I have simulated the Demodulator (Mixer) from Jesse Chen's Paper "Modeling RF Systems" (available on this webpage) in order to examine the problems with my mixer-model (http://www.designers-guide.org/Forum/YaBB.pl?num=1166542399thread).
With all simulation setups (qpnoise and pnoise) I achieved an noise figure deviation of +3.01db (at 27°C). Even if the nf-parameter of the model is set to 0, I get 3.01db NF.
And the Noise Contribution from the print menu displays the correct noise ratios according to the parameter settings.
Then I read the chapter "SSB and DSB Noise Figures" in B. Razavi's book "RF Microelectronics" (p. 183):
There is written that "the noise figure of a noiseless mixer is equal to 3db" due to the noise floor at the image band which is folded to the IF-frequency.
The Cadence documentation for qpnoise-analysis says that it calculates the SSB-Noise Figure.
Is this the reason for the deviation? Therefore 3db NF is correct for model-parameter nf=0?
So the software does not automatically subtract these 3db?
Thanks for your time,
Jochen
Re: noiseless mixer has 3db NF?
Reply #1 - Jan 19th, 2007, 6:27am
SpectreRF gives you both SSB_NF and DSB_NF.
SSB_NF and DSB_NF are  following.
             vn^2/Rl + kTo(G1+G2+...+Gn)
 Fssb = -------------------------------------
                kToG1
 Fdsb = -------------------------------------
                kTo(G1+G2)
kTo is the noise power at the input termination.
G1 is the primary frequency conversion from RF input frequency to IF output frequency.
G2 is the other frequency conversion from RF input image to the same IF output frequency.
G3 and higher are the higher order, low efficiency conversions
that occur as other input frequencies mix with harmonics of the LO to
appear at the IF output frequency.
If mixer is noiseless, vn=0.
G3 and higher are all zero in mixer behavioral model.
So NFdsb=0dB and NFssb=3dB.
Also see followings.
http://www.designers-guide.org/Forum/YaBB.pl?num=1162399761
« Last Edit: Jan 19th, 2007, 8:55am by pancho_hideboo »
Jochen
Nuremberg, Germany
Reply #2 - Feb 6th, 2007, 1:18am
Thanks for your quick answer pancho_hideboo!
Now I believe that my mixer delivers 3db NF_SSB without internal noise!
I have found another (old) thread where this is also discussed:
http://www.designers-guide.org/Forum/YaBB.pl?num=1042537924
Jochen
