cmolsen
NY
I'm using an port in the circuit, but not an nport.
I'm running under Linux - Spectre version 6.1.0.190 (dated 15 Aug 2006).
Here's the output log and the netlist when running with harmonicbalance=no where I get the "interp" error:
###################### running Spectre for comsrc_ac.scs spectre (ver. 6.1.0.190 -- 15 Aug 2006). Includes RSA BSAFE(R) Cryptographic or Security Protocol Software from RSA Security, Inc.
Simulating `comsrc_ac.scs' on cmoa30s at 10:37:48 AM, Mon Jan 22, 2007.
Circuit inventory: nodes 19 equations 186 bsim4 1 capacitor 7 inductor 2 mtline 4 port 2 resistor 13 vsource 4
****************************************** Sweep Analysis `sweep': prf = (-40 -> -30) ******************************************
++++++++++++++++++++++ sweep: prf = -40 (0 %) ++++++++++++++++++++++ Fundamental f1: period = 555.556 ps, freq = 1.8 GHz. Fundamental f2: period = 555.247 ps, freq = 1.801 GHz.
************************************************************************** Quasi-Periodic Steady State Analysis `sweep-000_anal': largefund = 1.8 GHz ************************************************************************** Important parameter values in pdisto iteration: start = 555.556 ps outputstart = 555.556 ps stop = 1.11111 ns period = 555.556 ps steadyratio = 1 step = 555.556 fs maxstep = 5.55556 ps ic = all skipdc = no reltol = 100e-06 abstol(V) = 1 uV abstol(I) = 1 pA abstol(U) = 1 u temp = 25 C tnom = 25 C tempeffects = all errpreset = moderate method = gear2only lteratio = 3.5 relref = sigglobal cmin = 0 F gmin = 1 pS maxrsd = 0 Ohm mos_method = s mos_vres = 50 mV
Warning from spectre at prf = -40 during periodic steady state analysis, during Quasi-Periodic Steady State Analysis `sweep-000_anal', during Sweep analysis `sweep'. Sweep iteration for `prf' = -40 terminated prematurely because of following error(s):
Error found by spectre at prf = -40 during periodic steady state analysis, during Quasi-Periodic Steady State Analysis `sweep-000_anal', during Sweep analysis `sweep'. Distributed components are not supported directly for Pdisto, Please use rational fitting technique by setting interp=rational. Warning from spectre at prf = -40 during periodic steady state analysis, during Quasi-Periodic Steady State Analysis `sweep-000_anal', during Sweep analysis `sweep'. Arithmetic exception in analysis `sweep-000_anal' .
Analysis `sweep-000_anal' terminated prematurely due to error.
--------------------- ... 10 more identical err msgs follow. ... ---------------------
**** Run Status for sweep analysis `sweep' **** Sweep iteration 1 (`prf' = -40) failed. Sweep iteration 2 (`prf' = -39) failed. Sweep iteration 3 (`prf' = -38) failed. Sweep iteration 4 (`prf' = -37) failed. Sweep iteration 5 (`prf' = -36) failed. Sweep iteration 6 (`prf' = -35) failed. Sweep iteration 7 (`prf' = -34) failed. Sweep iteration 8 (`prf' = -33) failed. Sweep iteration 9 (`prf' = -32) failed. Sweep iteration 10 (`prf' = -31) failed. Sweep iteration 11 (`prf' = -30) failed.
Warning from spectre. Arithmetic exception in analysis `sweep' .
Total time required for sweep analysis `sweep' was 250 ms.
Aggregate audit (11:00:18 AM, Mon Jan 22, 2007): Time used: CPU = 630 ms, elapsed = 10 s, util. = 6.3%. Time spent in licensing: elapsed = 20 ms. Virtual memory used = 5.05 Mbytes. spectre completes with 11 errors, 25 warnings, and 0 notices.
###################### //Generated for: spectre simulator lang=spectre global 0 parameters vg=0.5083 frf=1.8G prf=-30 vdd=1.2 simulatorOptions options reltol=1e-3 vabstol=1e-6 iabstol=1e-12 temp=25.0 \ tnom=25 scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5 \ digits=5 cols=80 pivrel=1e-3 ckptclock=1800\ rawfmt=nutascii rawfile="acdata"
include "tech/design.scs" include "tech/fixed_corner.scs" include "tech/process_ibm.scs"
TR0 (tr1 tr2 0 0) nfet_rf l=0.120u w=382u nf=128 m=1 par=1 ngcon=2 \ ad=6.912e-11 as=7.134e-11 pd=430.08u ps=437.56u nrd=0.06 nrs=0.06 \ rf_rsub=1 plnest=-1 plorient=-1 pld200=-1 pwd100=-1 lstis=1 lnws=0 \ rgatemod=3 rbodymod=1 ring=2 cwire=1 panw1=0p panw2=0p panw3=0p \ panw4=0p panw5=0p panw6=0p panw7=0p panw8=0p panw9=0p panw10=0p \ sa=5.5e-07 sb=5.5e-07 sd=3.6e-07 dtemp=0
Cg (2 tr2) capacitor c=800p Lg (tr2 100) inductor l=2u Cd (tr1 3) capacitor c=800p Ld (tr1 200) inductor l=2u
TL (1 2 0 0) mtline z0=50 td=1.5n
Vd (200 0) vsource dc=vdd type=dc Vg (100 0) vsource dc=vg type=dc
PORTin (1 0) port r=50 num=1 type=sine sinedc=0 \ freq=frf dbm=prf fundname="f1" \ freq2=frf+1M dbm2=prf fundname2="f2" PORTout (3 0) port r=50 num=2 dc=0 type=dc
save 1 2 3
sweep sweep param=prf start=-40 stop=-30 step=1 { anal qpss funds=["f1" "f2"] maxharms=[3 3] \ errpreset=moderate maxstep=10p annotate=status } ######################
Michael
