Oct 18th, 2024, 12:38pm
FOM of sigma-delta ADC (Read 2980 times)
Jan 22nd, 2007, 1:18am
Hi, Guys,
I read a paper in ISSCC 2006, "An 80/100MS/s 76.3/70.1dB SNDR ΔΣ ADC for Digital TV Receivers" .
It reads that Quote:
The ΔΣ ADC achieves a 76.3/70.1dB peak SNDR over a 3.2/4MHz bandwidth while consuming 23.8/34.4mW from a 1.8V supply, which leads to a 0.7/1.64pJ/conversion FOM
I calculated and found that the FOM should be 1.4/3.29pJ/conversion, which are twice of the FOM in that paper. My formula is
                                                Power
                               FOM=---------------------
                                         2^ENOB * bandwidth
where bandwidth is 3.2/4MHz respectively.
I am sure this formula is correct when I calculate FOM of nyquist ADCs, where bandwidth is ERBW or fs. But for an oversampling ADC, Mm...... Huh Am I wrong?
Best regards,
Yawei
Visjnoe
Re: FOM of sigma-delta ADC
Reply #1 - Jan 22nd, 2007, 3:38am
Hi Ygwuo,
first of all, there are a lot of FOM definitions, but the one you use is a very common one.
The difference between your calculated value and the one in the paper lies in the 'bandwidth' term in your equation: most likely, that should be the sampling rate Fs and according to the Nyquist theorem, this should be at least twice the bandwidth, hence the factor 2.
Kind Regards
Peter
Reply #2 - Jan 22nd, 2007, 6:11am
Hi, Peter,
I agree with you. Unfortunately, the authors didn't give their defintion of FOM. Smiley
Yawei
