Jul 17th, 2024, 8:14am
phase noise sim with spectre 6.0 (Read 1809 times)
rfmems
Jan 22nd, 2007, 5:53am
In vco phase noise simulation with spectre I always get this warning:
The Floquet eigenspace computed by Virtuoso(R) Spectre(R) PSS analysis appears  to be ill-defined. PNOISE computations may be inaccurate. Consider re-running the simulation with smaller reltol and `method=gear2only'.
I did everything as suggested, but could not solve this problem.
Does anyone have the same experience and solution to that? Thanks!
