rfmems
In vco phase noise simulation with spectre I always get this warning:
The Floquet eigenspace computed by Virtuoso(R) Spectre(R) PSS analysis appears to be ill-defined. PNOISE computations may be inaccurate. Consider re-running the simulation with smaller reltol and `method=gear2only'.
I did everything as suggested, but could not solve this problem.
Does anyone have the same experience and solution to that? Thanks!
